Monitor Help!
minecraftyeet1
Current PC: "For Now Because I Have A Habit"
CPU: Intel Core I7 6700K @4.5Ghz
Motherboard: Asrock Z170 Extreme4
RAM: 16GB G.skill TridentZ 3200Mhz DDR4
CPU Cooler: Thermaltake Water 3.0 360 Riing RGB Edition
Graphics Card: Nvidia Geforce GTX 1080Ti Founders Edition MSI
Case: Limited Edition Thermaltake View 31 Riing RGB
Power Supply: CoolerMaster V750 Fully Modular
SSD: Kingston HyperX Savage 240GB
HDD: 3TB Toshiba 7200RPM
Peripherals:
Monitor: AOC U2868PQU 4K 28" 60HZ
Keyboard: G.Skill Ripjaws KM780 RGB Cherry MX Red
Mouse: Razer Deathadder Elite
Mouse Pad: Razer Goliathus Speed Extended
Speakers: Creative SBS A250
Headphones: Razer Kraken Pro 7.1
5 minutes ago, SLIClocker said:
I would go 1440p, as the 1070 is better equipped for that.
10 minutes ago, I Need A PC Build ASAP said:
Which monitor would go best with this build:
http://au.pcpartpicker.com/user/Its_Joshua_S/saved/#view=3WdNnQ
Ask me questions if you like.
Either a 1440p productivity monitor, or if you're willing to pay more go with a 1440p, 144hz, 1ms gaming.
*I'd only do that if you play lower end competitive games like CSGO.
Do you want 144Hz?
Do you want G-sync?
Do you want ultrawide?
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Benq XL2430T is better than XL2411Z.
1070 can push 120+ fps maxed out at 1080p in 90% games.
At 1440p 144Hz u would have to lower settings to get near 144FPS.
If u are more into the pretty looking games with great story line u want 1440p for sure. U don't need 144Hz but it would be an advantage and make the gaming experience better. Unfortunately it would cost u a lot more than 1080p 144Hz screen.
Getting 60Hz monitor for your GPU is a waste of potential.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
I Just want a modern monitor for my setup pls
My PC Currently Is The P2-1320a.
Just go with the monitor i said, you won't need 1440p it is just a waste of money and frames.
Peripherals:
