I have this wireless mouse from NYK Nemesis S-80 Blackshark but I lost the usb receiver. I try to use wired mode and attach the nyk nemesis cable to my laptop but the mouse didn't work not a single movement. I used to use the cable and there's no problem, but suddenly I don't know either the cable broke or the wired mode is not working cause maybe the usb receiver is attach to other device that I apparently do not know about. Is there anyway like buying a new dongle or other alternatives so I could use this mouse again?
https://linustechtips.com/topic/1574923-wireless-mouse-usb-receiver/
I can't find this online but does the mouse have a slot to put the receiver into? If it does, did you try the cable when the receiver was in this slot?
The slot might have connections to check if the receiver is inserted so it can switch to wired mode. You could short the pins and see if that forces it into wired.
I haven't seen any mouse that does this so I'm only guessing this is the case.
On 4/5/2024 at 10:13 PM, LAwLz said:
I am getting pretty fucking sick and tired of the "watch something else" responses. It's such a cop out answer because you could say that about basically anything, and it doesn't address the actual complaints. People use it as some kind of card they pull when they can't actually respond to the criticism raised but they still feel like they need to defend some company/person. If you don't like this thread then stop reading it. See how stupid it is? It's basically like telling someone "shut the fuck up". It's not a clever responsive, it doesn't address anything said, and it is rude.
MKBHD is but an Apple propagandist and fanboy. Take his videos with a grain of salt, especially about anything Apple. In his video titled "I Visited Apple's Secret iPhone Testing Labs!", he has shown that he makes no effort to fact check Apple's claims, and takes it at face value. I do not believe he can be trusted as an Reviewer/Influencer.
bruh switch to dark mode its at the bottom of this page
VPN Server Guide
apparently this is a local brand from Indonesia, the brand already reply to my message and they sadly do not sell separate usb receiver and if the usb receiver broke, or lost basically the mouse is not usable anymore.
The usb receiver is not attach or plug in to the mouse like most wireless mouse. The mouse didn't have usb receiver slot to keep it in, so they basically separated mouse + usb receiver. I usually use the cable and it works fine, and I switch to wireless. And when I lost the usb receiver, I try to use wired mode but it didn't work which I don't know what could cause it.
Yeah it's defective then. You can't do anything about this unless it's under warranty.
It's a dead mouse anyway, perhaps you can take it to a nearby electronics repair store and see if they can figure it out for cheap?
VPN Server Guide
