I would like to buy some digital fan controller for my PC, since I'm running 7 fans + pump.
5 of those fans are for radiator and those are all the same.
Then I have 2 random case fans and a pump.
I don't have any problem with pump being connected to motherboard, and it's working great. But for fans, I would like to get more than what PWM can offer me.
Right now I'm using some utility from MSI command center, to control my fans, but it won't let me go below 50% speed.
At 50% speed, fans are spinning at 800rpm, but I would like my fans to spin at 500rpm.
For some reason I can't change speed of case fans ... not sure what's the problem, but doesn't matter what I change, those 2 fans will run at certain speed all the time.
Is there any other device than grid+ v2?
Looking for some with 4pin connectors instead of 3pin. Or that doesn't even mater?
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/622764-digital-fan-controller/
