Need help with Adobe Premiere Pro CC
Go to solution Solved by darkstar,
The 560Ti isn't supported by Adobe but there's a nice tutorial over at point in focus that shows you how to enable it.
http://www.pointsinfocus.com/learning/digital-darkroom/enable-cuda-in-premier-pro-cs6-without-a-quadro/
I don't know how to setup CUDA acceleration on Adobe Premiere Pro CC for Windows.
This is the Rig:
i7-2600k
Asus P8X58-Pro
Corsair H80
16GB DDR3
2x 60gb SSD
1x 1TB HDD
2x GTX 560Ti
The acceleration is comming only from the CPU, how do I use my GPU on Premiere Pro and Media Encoder CC?
The problem is that I don't know how to setup at Premiere CC, can some one help me with this?
(I know that Premiere only takes advantage from one GPU, but I also will be using After Effects).
https://linustechtips.com/topic/62249-need-help-with-adobe-premiere-pro-cc/
