What kind of build would I need?
Solved by CompArt,
4 minutes ago, Imakuni said:You know.... I'm pretty sure regular browsers can't handle 1k tabs at once, at the very least on the UI side. What you want isn't "a" PC, you want a lab of 50~100 different PCs for people to use.
lmao you might be right! I'm trying to use this program that can runs multi threaded browsers....except the browsers aren't displayed, unless in debug mode. So maybe it uses http get/post api? Not sure. But I'm trying to use at least 1000 threads.
