Socket and motherboard
Go to solution Solved by Skiiwee29,
2 minutes ago, dragoncurt said:
If a CPU and motherboard has the same socket can it work.
As I went into a manual of a motherboard (gigabyte ga-h55m-ud2h) it shows it does not allow the Intel Xeon X3440 but how come as it is the same 1156 socket and wondering if it would work if I did get the cpu.
Or if there is a mod that can make it work in the bios or something similar
Thanks
if the socket of the CPU matches the socket on the Motherboard, they should work. Sometimes it may require a BiOS update though if the board is older and is using a new CPU. IE the new X-99's or when intel used 1155 for both Sandy Bridge and Ivy Bridge.
Looking at the info sheet from Gigabyte, it lists 2 of its bigger brothers, the x3450 and x3480 on its supported sheet, so I dont see why the 3440 would not work.
Thanks
https://linustechtips.com/topic/620213-socket-and-motherboard/
Thanks
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/620213-socket-and-motherboard/#findComment-8003265
Oh right I get you now and I also did see that there is three xeons listed. Thanks I will buy it and try it out. Thanks
https://linustechtips.com/topic/620213-socket-and-motherboard/#findComment-8003269
Oh right I get you now and I also did see that there is two exons listed. Thanks I will buy it and try it out. Thanks
np, yea they both use the same architecture, same wattage, so should be zero reason that I can see spec wise for it to not work.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/620213-socket-and-motherboard/#findComment-8003270
Thanks as the CPU is cheap on ebay and thought why not as it has 4 cores 8 threads. Thanks
https://linustechtips.com/topic/620213-socket-and-motherboard/#findComment-8003272
