SSD Choice Please Help!
Go to solution Solved by Evann,
3 minutes ago, xX_Nyx_Xx said:
Hi, i'm having a bit of trouble because I can't decide what SSD for my OS. (This is for a gaming PC)
First option,
ADATA XPG SX930 2.5" 240GB SATA III MLC Internal Solid State Drive
560 MBps read
460 MBps write
Second option,
SanDisk SD8SB8U-256G-1122 X400 SATA 2.5" 256GB Internal SSD
540 MBps read
520 MBps write
Thanks for the help :)
i'd go for the AData one, because it's using MLC.
First option,
560 MBps read
460 MBps write
Second option,
540 MBps read
520 MBps write
https://linustechtips.com/topic/619913-ssd-choice-please-help/
First option,
560 MBps read
460 MBps write
Second option,
540 MBps read
520 MBps write
https://linustechtips.com/topic/619913-ssd-choice-please-help/#findComment-8000139
