9 minutes ago, Aruterisu said:
How much better is the i5 6500 , compared to my current a8 5600k and what performance gain would i obtain by upgrading to it.
I have currently got a 480.
Oh jesus mate godly fps gains. However just go for the old i5 4460 or something like that its cheaper and will perform the same as a i5 6500
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/619581-cpu-help-i5/#findComment-7996725
That a8 is definitely holding back that 480, going to a 6500 you will be a big improvement.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/619581-cpu-help-i5/#findComment-7996726
11 minutes ago, Aruterisu said:
Are you sure about that?
Yeah, your 480 most likely is acting like a 270 in games, and considering the massive improvement in single threaded performance you will see 30-40fps differences if not more.
https://linustechtips.com/topic/619581-cpu-help-i5/#findComment-7996811
Seeing as how AMD could only compete with i3s in gaming performance on their best chips... Yeah, an i5 would be a huge step up
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/619581-cpu-help-i5/#findComment-7997279
