Alright guys, just wanted to share a couple of pictures I have of my first ever pc build that I completed a couple months ago but just haven't got around to posting until now.
Components:
CPU - Intel Core i5-4460
CPU Cooler - be quiet! Dark Rock 3
MOBO - MSI Z97-Gaming 3
Memory - Kingston HyperX Fury Red 16GB
Storage 1 - SanDisk Z400s 256GB SSD
Storage 2 - WD Blue 1TB
Graphics Card - Sapphire Radeon R9 390 Nitro
PSU - Corsair RMx 650W
Case - NZXT S340
I know this isn't the most high end or earth shattering build but as I said it was my first attempt and it is more than capable of doing what I was wanting prior to the build.
I am currently thinking of possible near future upgrades.
Any feedback is welcome.
Hope you like it!
Personal Build
i5-4460 | BeQuiet! Dark Rock 3 | MSI Z97 – Gaming 3 | Kingston HyperX Fury Red 16GB | Sapphire R9 390 Nitro | SanDisk Z400s 256 GB | WD Blue 1TB | Corsair RMx 650W | NXZT S340
https://linustechtips.com/topic/619464-first-ever-build/
Congratulations on your first build, it looks amazing, just going to say that you have great taste. The red, silver, and black look great together.
CPU: AMD A8-6600K 3.9GHz(OCed to 4.5GHz) Quad-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: MSI A88XM-E45 Micro ATX FM2+ Motherboard
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive
Storage: Seagate Barracuda 120GB 3.5" Internal Hard Drive
Video Card: EVGA GeForce GTX 760 4GB Dual FTW ACX Video Card
Case: Silverstone TJ09-BW ATX Full Tower Case
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply
https://linustechtips.com/topic/619464-first-ever-build/#findComment-7995483
7 minutes ago, Marcus Torre DeProspero said:
I like it a lot. Great future upgradability, Great look overall. I am sure that you have enough fans to keep good overall airflow and even if not then you can easily get some fans to do so.
yeah I have the two standard fans that came with the case plus an addition 120mm fan (that I added after the pictures as it was kind of an after thought) configured with one fan at the front drawing air in, one on at the rear and on at the top both blowing air out. I have thought about possibly adding an additional fan but my temps seem to be okay.
Personal Build
https://linustechtips.com/topic/619464-first-ever-build/#findComment-7995491
Thanks glad I'm not the only one who likes how it turned out
Personal Build
https://linustechtips.com/topic/619464-first-ever-build/#findComment-7995503
2 minutes ago, fully1208 said:
yeah I have the two standard fans that came with the case plus an addition 120mm fan configured with one fan at the front drawing air in, one on at the rear and on at the top both blowing air out. I have thought about possibly adding an additional fan but my temps seem to be okay.
okay well then you won't have any problems with airflow and temps then. I honestly can't find any suggestions for you. You did so well that I can't say anything bad about it.
https://linustechtips.com/topic/619464-first-ever-build/#findComment-7995505
