Well this is my first computer build. My friend wanted a PC so I decided I could build one. I had a minor issue of putting the power and reset on the opposite one but I fixed that. Had fun building it so look forward to many more builds. Hopefully in the future maybe a little more exciting.
Specs:
AMD FX-4350 4.2 GHz
XFX Radeon R7
Gigabyte GA-78LMT-USB3
Raidmax Atlas Mid Tower Case
WD Blue 1TB 7200 RPM
HyperX Fury 8GB DDR3 1600
https://linustechtips.com/topic/618930-first-build/
Specs:
AMD FX-4350 4.2 GHz
XFX Radeon R7
whats that psu?
https://linustechtips.com/topic/618930-first-build/#findComment-7989415
