QX6850 Temps???
Go to solution Solved by Jumper118,
1 minute ago, TheMediumNinja said:
Hmmmm ok thankyou. I also notice when i pull my Intel stock heatsink it doesnt seem the past has spread out much, like the heatsink isnt getting close enough to the processor, any ideas there?
yes. dont use an intel stock cooler. the extreme cpus came with a different version like this for a reason:
also the qx6850 overclocks very well and push pin coolers do not spread paste well as they dont apply much pressure.
thats a bit warm. it shouldnt really be above 70c under load.
Anybody know what temps while idling and full load for QX6850? Mine idles at around 58 and under load it goes a little over 80. I've read all over the internet but it seems everyones temps are a lot lower than mine....
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988192
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988212
just change it :)
You can buy thermal paste for like 2$ probbably.
Also make sure to blow away dust from heatsink :)
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988229
Rig Specs:
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988231
Ah, ok cool. Thank you, i bet thats the problem. It does make sense since this thing draws a lot of power. power=heat. I also assumed that was the reason for it not spreading. Defiantly will go do some research on cooling fans. Any recommendations??
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988305
cooler master hyper 212 evo.
Rig Specs:
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988372
Cryorig H7 or Be Quiet! Pure Rock.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988374
4 minutes ago, TheMediumNinja said:
I looked at all the fans and due to the mass amount of good reviews on the cooler master i went ahead and bought it in Amazon Now, should be here in a couple hours. Thanks guys
good :) i'm using one right now on a 3570k@4.7ghz.
Rig Specs:
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988652
Well I ordered it and apon reading more it doesn't say it supports lga 755. I'm really stupid lol, I assumed it just supported all cpus based on the fact it had 4.5k reviews on newegg. Am I wrong about this?? Lol
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988797
I assume the Hyper 212 EVO. According to google it should fit but please read the manual.
USEFUL LINKS:
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988803
Ya I read the manuel and it does. Not sure why amazon doesn't have 775 listed. Flash alarm. I'll update with temps and overlocks later tonight.
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988830
ok. last time i checked it supported 775
Rig Specs:
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7988835
Got it all installed and did some stock speed benchmarks. Defiantly a difference. Temps and Fan speeds below. I also ran some temp tests before, about 60 idle and around 80 under full load.
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7991067
Final OC 3.5ghz. Temps are good and i wanted to push to 3.6 or 3.7 but if i upped my voltage it wouldnt change in windows and if i added any more host clock windows would have a error and load the windows repair, so 3.5 it is. Stable ran for 1 hr with the highest core at 59, not in this screenshotfinaloc.PNG
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7991661
much better :)
Rig Specs:
https://linustechtips.com/topic/618823-qx6850-temps/#findComment-7991686
