3 minutes ago, Scitesh said:
what is the difference b/w
vsync
adaptive sync
separate sync(viewsonic monitors)
freesync
G-sync
what should i look for(gtx 1080..ordered yet to arrive)
vsync- it locks the frames so they match the monitors refresh rate. If you GPU can do 80FPS in game, if you turn on vsync of a 60Hz monitor, you will only get 60FPS.
Adaptive vsync- same principle but only turns on when it detects tearing
separate sync- not sure
freesync/gsync (both work the same way)- the GPU tells the monitor when to refresh so if the card does 80FPS, the monitor will refresh at 80Hz. You need a special monitor for that though. Usually comes with a premium (nvidia!!).
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/618648-plz-help/#findComment-7986133
samsung s27e510c is a freesync 60hz monitor
(the only gsync ones i found are 144hz)
https://linustechtips.com/topic/618648-plz-help/#findComment-7986171
I mentioned nvidia because they charge the manufacturer to put in the gsync module whereas AMD does not. That's why freesync monitors are so much cheaper than gsync monitors.
https://linustechtips.com/topic/618648-plz-help/#findComment-7986239
