So , i wanna know how would it be best to install fans and power supply into case .
I wanna know on what side i would install power supply , either it'll get air from case or from outside of the case.
And fans  , i'll buy Corsair 200R case , and i'll get two Corsair FAN , AF140 , LOW NOISE HIGH AIRFLOW fans .
So i wanna know where do i install them if i'll have 2 stock ones
-- My Rig --
| CPU: Intel i5-4670K @ 3.4GHz | GPU: Gigabyte GTX 760 Windforce OC Edition |Mobo: MSI Z87-G45 Gaming | RAM: Corsair Vengeance Pro DDR3 (2X4GB) 1600MHz | Case: Corsair 200R | PSU: Corsair Enthusiast 80 Plus Bronze TX650W | HDD : WD Caviar Blue 1TB Sata 3 600MB/s 7200rpm 64MB |
| Running on Win 7 64bit Ultimate | Samsung SyncMaster T24B300 23,6 Inch  FULLHD Monitor |
https://linustechtips.com/topic/61852-cooling-case/
If you have 2 fans total you always put one in front as the intake and one in the back as the outtake so you have a constant flow of air throughout the case.
https://linustechtips.com/topic/61852-cooling-case/#findComment-843707
For the psu a lot of times is a personal choice. It's only necessary to install with the fan up, intaking from the system, if you're running the case on carpet or there is something blocking the intake. Vise versa, if you have a high-end non reference gpu blowing hot air around the bottom of your case it would be better to have the psu intake facing down. Hope this helps.
Corsair 250d - - Delidded i7 4770k @ 4.4GHz (1.15v) - - Asus Maximus VI Impact - - Corsair h100i
Asus DirectCU II OC GTX780 - - NZXT x41 & G10 w/ Push/Pull Noctua IndustrialPPC's - - Corsair ax760i
16GB Corsair Vengeance 2133Mhz  - - Samsung 840 pro (boot) - - Samsung Evo (gaming) - - WD green HDD (data)
https://linustechtips.com/topic/61852-cooling-case/#findComment-844081
