I am trying to make a spider web in 3DS Max and was unsuccessful so I found this file of an editable Spider Web preset, but... I can't figure out how to open it in 3DS. Its been 2 hours with no avail, migrane is setting in.
The link below with take you to the place I downloaded it at. You're my only hope!
http://www.maxplugins.de/max2016.php?search=spider&sort=Author
https://linustechtips.com/topic/618476-3ds-max-import-please-help-migrane/
The .mcg file type isn't natively supported by 3DS Max.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
any idea oh how I can work around this, I am very novice with 3ds max. I used inventor and creo for years buts its turning out be quite different... :(
You would need to download a plugin that allows importing of .mcg files.
