Hi,
At the moment I am looking at my options for a budget gaming pc build. My budget is between €600-€800. These are the parts:
-CPU: I5 6400 (BLCK oc to 3.8ghz)
-Mobo: MSI 170 Tomahawk
-Memory: Kingston hyperx Fury DDR4 2x4
-CPU Cooler: Cooler Master hyper 212 evo
-Chassis: NZXT Source 340
-GPU: AMD RX 480
-Fans: Two 140mm NZXT fans
-A keyboard and a gaming mouse
Will a 450 watt PSU be enough to power it?
Thanks in advance!
https://linustechtips.com/topic/618265-will-450-watt-be-enough/
6 minutes ago, Revess said:
Hi,
-GPU: AMD RX 480
Thanks in advance!
What 450W unit is it? 450W is enough but you may want a higher quality PSU.
https://linustechtips.com/topic/618265-will-450-watt-be-enough/#findComment-7981687
5 minutes ago, Revess said:
I might get the corsair VS450
I don't think that's a good unit...
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/618265-will-450-watt-be-enough/#findComment-7981725
Run away.
Get a Seasonic S12. Also, with things being released about the RX480 drawing too much power from the PCI slots it may be better to get a used 970 over the 480.
https://linustechtips.com/topic/618265-will-450-watt-be-enough/#findComment-7981738
