[Build Log] [WIP] Sashimi Skylake
Sashi
So I built my skylake computer that is now wall mounted.. well that is changing.
Wall mounted PC is great but servicing is so time consuming especially for watercooling.
So I am rebuilding my PC into a real case :).
Specs
Case: Fractal Design S - No window (sadly the case will sit flush to the wall/close to the wall where the window would be so I can't see it anyways)
CPU: Intel Core i7 6700k
Motherboard: ASUS Z170-A
RAM: GSkill Ripjaws 16GB DDR4 Ram
SSD: Samsung 850 EVO 250GB SSD
HDD: WD Scorpio Black 750GB HDD
GPU: GTX 770 (Will probably upgrade to a 1070... maybe 1080)
PSU: XFX 750W Black Edition
Watercooling Parts
Pump: D5 Vario
Reservoir: Bitspower Water Tank Z-Multi 150
Radiators: 2x Dazmode 360mm Extra Slim Radiator
Fans: Scythe Gentle Typhoon AP-15
CPU Block: EK Supremacy EVO
GPU Block: EK GTX 770 + Blackplate
Fittings: Bitspower 12mm OD Rigid Tube - Matte Black
Tubing: Crystal Link (Acrylic) Tube 12mm OD - White
Misc
3-way Splitter, T Block Crossconnect Adapter - Matte Black
5mm Spacer Adapter - Male-Male G1/4 - Black
QD3 Male Quick Disconnect No-Spill Coupling, Male Threaded G1/4 - BSPP - Black
QD3 Female Quick Disconnect No-Spill Coupling, Compression for 10mm x 13mm (3/8in x 1/2in) *Black*
15mm Spacer Adapter Male/Female - Matte Black
90 Degree Rotary Adapter M/F G1/4 - Matte Black
14 mm Rotary Spacer Adapter - Male-Male G1/4 - Black
Bitspower Drain Valve - Matte Black
● Thermaltake Core P5 ● ASUS Z170-A ● Intel Core i7-6700k
● EK Supremacy EVO ● 2x 8GB GSkill Ripjaws
● EVGA GTX 770 ● Samsung 850 EVO 250GB ● XFX 750W Black Edition PSU
39 minutes ago, mrchow19910319 said:
Post some more pics please!
xD
Haha I will!
Before and after pics would be cool, before you disassemble the wall mounted one that is.
Used to be on the side of the closet.. so bare now
Being disassembled
Some parts came in!
