Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/617726-1200-mini-itx-build/#findComment-7975156
Really tried to fit a GTX 1080 in the budget but with the big SSD and SFX PSU I couldn't without it being $100 over :/
GTX 1070 is sitll good too. So yay for $150 under budget?
I cheaped out in some places so feel free to fill in some gaps (i5 6500 -> 6600k?)
Honestly you don't need $1200 to play those games at 1080p at all.
PCPartPicker part list: http://pcpartpicker.com/list/FV9RGf
Price breakdown by merchant: http://pcpartpicker.com/list/FV9RGf/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($197.99 @ SuperBiiz)
CPU Cooler: CRYORIG C7 40.5 CFM CPU Cooler  ($34.99 @ OutletPC)
Motherboard: ASRock H110M-ITX/ac Mini ITX LGA1151 Motherboard  ($67.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($31.99 @ Newegg)
Storage: PNY CS1311 480GB 2.5" Solid State Drive  ($109.99 @ Amazon)
Video Card: EVGA GeForce GTX 1070 8GB Founders Edition Video Card  ($449.99 @ SuperBiiz)
Case: Silverstone RVZ01B-E HTPC Case  ($64.99)
Power Supply: Silverstone 500W 80+ Gold Certified Fully-Modular SFX Power Supply  ($94.99 @ B&H)
Total: $1052.92
Generated by PCPartPicker 2016-06-28 15:15 EDT-0400
https://linustechtips.com/topic/617726-1200-mini-itx-build/#findComment-7975163
Hi, I went with a 6600k so you can OC and get the most of very unoptimized games like WoW (which really likes single threaded performance).
For the GPU all the prices are crazy here, Nvidia promised retail prices that are non-existent as of today. However the GTX 980ti are near the $400, they perform just like the GTX 1070s but cost less.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($234.99 @ NCIX US)
CPU Cooler: Thermalright AXP-100 Muscle 44.5 CFM CPU Cooler  ($49.95 @ Amazon)
Motherboard: EVGA Z170 Stinger Mini ITX LGA1151 Motherboard  ($123.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($52.99 @ Newegg)
Storage: A-Data Premier SP550 480GB 2.5" Solid State Drive  ($109.99 @ Amazon)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($439.99 @ Newegg)
Case: Silverstone RVZ02B HTPC Case  ($69.99 @ Amazon)
Power Supply: Corsair SF 600W 80+ Gold Certified Fully-Modular SFX Power Supply  ($119.99 @ Amazon)
Total: $1201.87
Generated by PCPartPicker 2016-06-28 23:33 EDT-0400
I chose the Silverstone RVZ02 instead of the rvz01 you suggested, I think this second version looks better and has better internals. They cost the same.
For the PSU I went for the Corsair SF 600, it's the best SFX PSU on the market, it's very quiet (silverstone's SFX PSUs can be loud), has 600W and really awesome cables.
I have experiences with the SP550 from Adata, so I picked it up as your SSD, I have the 240gb version and is good, the 480GB version is supposed to be better.
16GB ram seems good for the system, if you plan to upgrade to 32 GB in the future, I suggest you get a single 16GB stick, so you can use the other slot later down the road.
The Cooler I picked really needs more popularity, as it's one of the best (if not the best) short CPU cooler, it has a massive fan and a huge array of fins (being that they fit on this case). You are not going to do a major overclock with it, but it's comparable to a Hyper 212 EVO in performance, pretty good despite the size, 4.2GHZ should be achievable while keeping the acoustics mostly controlled.
So overall I went for a balanced, yet very powerful system that is still quiet despite the form factor (usually really small cases and PSUs have very small fans, and those fans are noisy).
You can get a better price than the $1201 my list has if you do rebates, and purchase from other websites like SuperBiz. I only have NCIX US, Newegg and Amazon selected, as those are the best retailers for PC components IMO. Also I found rebates annoying as hell, so I don't include them, you can if you wish.
https://linustechtips.com/topic/617726-1200-mini-itx-build/#findComment-7977393
