So i'm looking for a keyboard for my new gaming rig.
Something similar to the image attached. I want really nice key caps like those, it needs to be available in the uk too.
I dont have a tonne of money so i dont want to spend much either.
I dont care about the switches although i do prefer MX blues.
Any ideas? Thanks!
MY RIG
I5 6600k
16gb Corsair vengeance 2666mhz
MSI Gaming X 1070
WD blue 2tb
samsung 850 evo 250gb
EVGA supernova G2 650w
https://linustechtips.com/topic/617656-help-finding-a-keyboard/
build your own? That way you can have it exactly how you want it to be :)
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974367
Yes, that is an option but im not very confident at electronics.
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974599
True true, I feel like I've seen that keyboard somewhere before...anyway, you could just find a keyboard you like and get some custom keycaps onto em :P
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974606
Know anywhere to buy custom key caps?
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974609
Within the UK, not really...US companies then quite a few :P
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974625
Hmm, should i import some?
Also do you know some not too expensive mx blue keyboards?
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974630
Cherry or any?
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974634
Cherry mx blue or something similar such as the razer green one.
One last question, form factor? Full, TKL, CM's 80%, 60% ect.
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974651
Around the size of the apple wireless keyboard. the small one :)
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974656
KBC poker 60%, Ducky mini (they are both quite expensive) for cherry switches, CM's Quickfire Rapid i for TKL but they are quite cheap (with cherry switches), CM quickfire TK are cheap and pretty good but is bigger than that apple wireless keyboard (cherry switches) and I guess look around for 60% keyboards/TKL with blue switches for cheap, non cherry switches :P
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974691
Are there any ones similar to the KBC poker 60% because i like that one but they are not available in the uk :/
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974707
Say what?
Look at the post below, I'm a tad idiotic at times :P
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974715
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974717
3 minutes ago, Mr.Meerkat said:
Ahh! Would that be a good keyboard that would last a long time?
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974728
Well from what I've heard, KBC Poker's are pretty damn high quality and they are comparable with the likes of ducky and WASD (aka the tier above Corsair and Logitech) so I'm guessing they should last a long time :).
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974744
Hmm, okay! I think i will go with that then.
I know this isnt the right place but can you check my pc parts as im about to buy them :)
http://uk.pcpartpicker.com/list/2GBFd6 Can you reccomend a better case?
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974754
Hmmm...looks pretty good to be honest, I'm unsure what better case would suit you personally however :/. I would say it's fine and go for it (p.s. that cooler may be a bit underwhelming but should be fine at cooling a stock 6600k.)
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974805
I dont plan to overclock the cpu for a year or so so when i do i will get a abtter cooler
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/617656-help-finding-a-keyboard/#findComment-7974809
