has anyone tested/messed with the 2017 version of 3ds max. i have to get it on my new computer and thought about upgrading so what are your thoughts
also what are the differences between the 2016 and 2017
CPU: i5 4690k  (overclocked to 4.3ghz)             CPU Cooler: Cryorig h7                 MOBO:  Msi Z97 pc mate             RAM: 8GB HyperX 1600 blue
GPU: rx480  4gb                                                 CASE: Corsair Spec-01 red              OS: Windows 10
PSU: EVGA 500   watt                                       SSD:    v60gb Mushkin ssd                HDD: 1000GB WD BLUE
https://linustechtips.com/topic/617395-3ds-max-2017/
2 minutes ago, thekeemo said:
Its an incremental upgrade nothing to write home about.
does it run better the 2016
and are there any errors
https://linustechtips.com/topic/617395-3ds-max-2017/#findComment-7971211
i thought we were still in 2016?
https://linustechtips.com/topic/617395-3ds-max-2017/#findComment-7971215
I decided to get 2016 because it is fimiliar
https://linustechtips.com/topic/617395-3ds-max-2017/#findComment-7978077
