I've been running a HD6770 for the last year or so, but all the ports on it have died. I am looking for a cheap GPU that I could play games on on low quality whilst saving for a higher end card. I am planning on running 2 monitors off of it using any combination of DVI, HDMI or VGA (I have a monitor that can display 1080p through VGA) I'm in the UK and am not really wanting to spend any more than £50.
Cheers
https://linustechtips.com/topic/6166-need-cheap-replacement-card/
you can get a 7770 from http://www.scan.co.uk/shop/computer-hardware/all/gpu-amd/radeon-hd-7770-pci-e if your budget is willing to stretch
Current Rig : Corsair 330r, ASRock Z77 Extreme6, 3570K, 8gb Crucial Balistix, KFA2 GTX680 White, Corsair AX750, Xonar Essence STX, Beyerdynamic DT770
https://linustechtips.com/topic/6166-need-cheap-replacement-card/#findComment-68120
