PfSense Port Forwarding Issues
Here is a screenshot of my port forward settinsgs https://gyazo.com/f12d6e09b2723a7dff72d3f96a839d30 I have a minecraft server and the firewall on the server machine is disabled. When I do a port check it says the port is open but when trying to connect it says it cant find the server pls help.
UPDATE: Connecting with ipv6 works find but not ipv4
UPDATE2: I have revcieved this error and I don't understand what it means.
  • There were error(s) loading the rules: /tmp/rules.debug:148: rule expands to no valid combination - The line in question reads [148]: pass in quick on $WAN reply-to ( em0 [myipv6 adress] ) inet6 proto { tcp udp } from any to 192.168.1.105 port 25565 tracker 1466974036 keep state label "USER_RULE: NAT " @ 2016-06-26 13:58:06
https://linustechtips.com/topic/616574-pfsense-port-forwarding-issues/
are you sure your using the correct LAN IP?
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
2 hours ago, Denboy_Kad said:
lan works find its just connecting via wan and I assume its a problem with the port forwarding or pfsense
Have you had someone else try to connect to it that is outside your local area network? Because if that works then you probably need to make sure that NAT reflection is enabled or setup properly since you are trying to connect to it from inside your network but using the external ip address.
Main PC:
OS: Windows 10 Pro, Motherboard: Asus ROG Strix X570-E Gaming, CPU: Ryzen 9 3900X, Cooler: NZXT Kraken X63RAMCorsair Vengeance RGB Pro 32 GB DDR4-3200 CL16, GPU: Asus GeForce RTX 2080 SUPER STRIX GAMING, Case: NZXT H710, StorageSamsung 970 Evo Plus 1 TB NVME, Sabrent Rocket 2 TB NVME, and WD Blue 4TB 2.5"PSU: NZXT C 850 W 80+ Gold
Home Network:
Router: Ubiquiti USG-3, APs: Ubiquiti UAP-AC-LR and Ubiquiti USP-AC-PRO, Switches: Ubiquiti US-16-150W
People from outside my network cannot connect
Just out of curiosity change "filter rule association" to pass. I feel like something messed up there. If that doesn't work then I would delete the port forwarding rule and anything associated with it and start over.
https://doc.pfsense.org/index.php/How_can_I_forward_ports_with_pfSense
Main PC:
Home Network:
Ive re done the port forward and still no results there is an associated rule with the port forward.
Also when I do a port check it says its open but when trying to connect in minecraft it says it cant connect to the server.
I feel like that may be the issue (by that I mean your associated rule). If you are just forwarding minecraft through that port then you shouldn't need a filter. Just set it to pass
This is because the port can be open but it something is wrong with the rule/filter then its going to cause issues and you shouldn't need
Main PC:
Home Network:
With an associated or with it set to "pass" it doesnt work.
What does the NAT rule look like that you created to go with this port forwarding rule. I saw that someone brought it up in the previous post about this issue.
Main PC:
Home Network:
I'm just trying to get a better picture of what is going on inside of the pfsense box and see if there is anything that we are missing.
Main PC:
Home Network:
Action:Pass
Interface:Wan
Adress Family:IPv4
protocol: tcp/udp
I don't know if you have tried this already but change "Destination" to any inside of the port forwarding rule, then go to Interfaces>WAN and make sure that both "block private networks and loopback" and "block bogon networks" are unchecked.
Main PC:
Home Network:
I think the main problem is probably the WAN interface so I would change that first and then change destination to any if that fails. (hopefully it doesn't)
Main PC:
Home Network:
Both of those failed... I have no idea what else I can do to fix this
Use hamachi...
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
The point of port forwarding is to NOT use something like hamachi
There comes a point where you just have to accept something is not going to work.
Main Gaming Rig:
Secondary PC:
I have a feeling that there is a solution to this
Then wait for the other guy, there's no need to create a second thread...
Main Gaming Rig:
Secondary PC:
