Anyone else have this problem? Anyone know of a quick fix? I know its in beta but i'm sure this isn't very common.
EDIT: not talking about 3D vision and it seems to be a driver problem. So my GPU is stuck at 405Mhz and it should be running at 850Mhz when there is a 3D load.
https://linustechtips.com/topic/61637-bf4-gpu-stuck-in-2d-mode/
Yeah, I'd assume that 3D support isn't in the beta.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/61637-bf4-gpu-stuck-in-2d-mode/#findComment-840459
Maybe they haven't added support for 3D yet?
2D clock speed mode sorry I forgot about 3D vision because I don't use it. Also it turns out tis a driver problem.
https://linustechtips.com/topic/61637-bf4-gpu-stuck-in-2d-mode/#findComment-840460
*imagines BF4 as a platformer*
... Da fuq.
*realizes what is being talked about*
*facepalms*
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/61637-bf4-gpu-stuck-in-2d-mode/#findComment-840462
I forgot to mention I wasnt talking about 3D vision im talking about 2D and 3D clock speed settings. I edited the post and it seems to be a driver problem.
https://linustechtips.com/topic/61637-bf4-gpu-stuck-in-2d-mode/#findComment-840466
Are the clocks stuck in other games as well? If so, reboot.
https://linustechtips.com/topic/61637-bf4-gpu-stuck-in-2d-mode/#findComment-840523
If it's not switching modes to get it working as a work around download EVGA preceision (maybe msi afterburner has this) and enable K-boost when playing. That would be the only thing until Nvidia releases another driver.
        Sager NP9370EM - I7 3630QM - 680m 1045Mhz - 8gb 1600mhz ram - 240gb msata 750gb hdd
https://linustechtips.com/topic/61637-bf4-gpu-stuck-in-2d-mode/#findComment-840566
I use MSI afterburner.
https://linustechtips.com/topic/61637-bf4-gpu-stuck-in-2d-mode/#findComment-840589
