11 inch thin laptop suggestions?
Go to solution Solved by don_svetlio,
Lenovo Yoga or X1 Carbon?
A family member of mine wants to get a laptop that she can fit in her bag/purse or whatever. She's been looking at a 11in MacBook air but I can't really live with myself if I let her spend 1200$ on a computer with 4gb of ram and a OS that she isn't used to that probably doesn't support the software she currently uses, which means that since I have a MacBook Pro (got it basically for free from the school when I finished "collage") I'll have to help her with that for the rest of my life.
So, any suggestions of a small and thin laptop that's under 13in and max around 1300$.
Thanks.
Meow.
X1 Carbon is too expensive.
The Yoga seems good but it would be cool with a bit more performance.
Meow.
Unless she's doing gaming or any serious work/heavy multitasking then a simple ULV i3 or i5 would be fine.
True. Will probably go for it.
Meow.
Just avoid the Core M CPUs - those are crap
Isn't the Yoga running core M though?
Meow.
Only the low-end one - the 13' 900$ one is a i7 ULV
Ah, the problem is that she "neeeds" one that's below 13in.
Meow.
13' is incredibly tiny - 11' is tablet territory - if you want a 10-11' device get a high end tablet
I know, that's what I've been telling her xD
Meow.
Yeah, the Yoga is a mix of the two and the 13' one is a great laptop and also dubs as a high-end tablet
Seems like the 13in models are also running Core M lawl.
Meow.
Check on Lenovo's site.
Ah I see. :P
Imma try to convince her, thanks for the replies. ^_^
Meow.
13 minutes ago, SlimeyStuff said:
Ah I see. :P
No problem. Hit me up if you need help.
check the dell outlet store for a 13" xps, smaller than a typical 13" and quite close in size to the 11" air.
