1 minute ago, kakhat said:
gtx 960 4 gb overclocked
Check frequencies and temperature in something like GPU Z or Afterburner. If it is below 1000 MHz, then you've got a problem. My recommendation is to uninstall the drivers and reinstall new ones. That worked for me when I had this problem. :P
Well if you added a mod since prior to the issues or changed drivers I'd recommend reverting to the software from that point, otherwise check to see if something odd is happening with the GPU clocks speeds and power usage.
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
