Hello! I have an old AR Drone battery and my 2 year old brother is obsessed with flying things, so I charged the battery with a universal smart charger and I tired it out (the battery says only to charge at 1.0 Amps and the charger has an option to charge at 1.0 or at 2.0, so obviously I charged it as 1.0). The battery seems to be dead, I get no response from the drone when I turn it off (I have no way of knowing if the drone is dead, so may only thought is to get a new battery).  I saw on amazon a batter that fits my drone and it says to charge at 1.3 Amps, is it viable to charge it at 1.0 Amps? I know it might not work because it wont have enough amperage to charge the battery, or should I charge it at 2.0 Amps? Which I know may also damage it.  but, a 0.3 amps difference probably won't make a difference (at least I think so).
To make it short, can I charge a battery that requires 1.3 Amps with a 1.0 or 2.0 Amp charger?
https://linustechtips.com/topic/615420-charge-batteries/
normally you can charge every battery below it's advertised charging speed. I load my rc battery packs well below advertised speeds and never had problems.
BUT do not charge it at 2A, it will damage it. Slower is no problem, faster indeed
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/615420-charge-batteries/#findComment-7949876
Thanks for your response! I really appreciate it!
https://linustechtips.com/topic/615420-charge-batteries/#findComment-7949883
