Fitting not fitting?
Solved by W-L,
1 minute ago, Joe11221 said:Yes they are bitpower fittings. Is that significant? Thanks for the suggestion! Will soon try.
It's not an um common thing with the Bitspower fittings they seems to have a bigger interference fit with the tubing than with some of the others out there.
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
