Recommended pump for a compact loop?
Go to solution Solved by W-L,
7 hours ago, MontyBonjangles said:
-SNIP-
I would to go with something like a DDC pump ideally with a heatsink since they can get quite warm, or a compact D5 pump res unit like this:
http://www.xs-pc.com/reservoirs/d5-tank-reservoir-v3
Hey guys
I was just wondering what people would recommend as a rough estimate of a pump would be on a loop.
I'm planning a compact build in the raijintek aeneas and was wondering what sort of pump would be good for the space, unfortunately I am not experienced with pumps in this regard, and i'm not sure what would be adequate.
Here's what I've got in mind:
2x240mm radiators.
1x Cpu Block.
1x Gpu Block.
I was thinking of a compact pump/res combo like the XSPC ION or similar thing, but im not sure if it will be enough for an extra rad and a gpu block.
Any suggestions?
M.B
Golly, I sure hope that my internets are all in a safe place...
https://linustechtips.com/topic/614907-recommended-pump-for-a-compact-loop/
-SNIP-
15 hours ago, airdeano said:
i always advocate for the D5 if that is not 'compact' enough. the DDC 18w would be best, the 12w can go the distance, but there is a path for better.
 I went with a 12w DDC with a res top in the end as I found it on sale. Ta for the help.
