Evening Linuslings
Perhaps you can share some insight on this problem i'm having:
So at work we've got a macro enabled word template that we store on a network location; users have been having problems with it so i've taken a look at how i could fix it.
Issues:
inability to use macro boxes (even after enabling macros)
constant save-as loop when trying to close the document
Opening certain documents causes word to crash
- These issues are common to a multitude of users
Attempted remediation - i've done some fiddling with advice from ms technet/other forums - the only real significant change i've since made is to change the document template (File --> Options --> Addins --> Manage --> Templates) from the document name/proprietary template to Normal.dotm
This addresses the issue of the endless save loop - partially.
However, what I've noticed is that when you open the document for the first time - you will have the above problems. if you close it immediately after opening - then open it again a second time, you shan't be plagued by the aforementioned issues.
At this point in time i'm not sure where to head from here -
Any pointers chaps?
Cheers,
Hasufein.
https://linustechtips.com/topic/61481-ms-word-template-problems/
