Hi guys! Today I need help with my main display. I'm very frustrated and can't seem to get my display fixed. Earlier today my main display(BenQ GW2255) was working fine. I decided to disconnect it from my PC and connect it to my Wii U to do a factory reset. I did what I was going to do, and when I connect it back to the PC, it wouldn't recognize it. I use a Single link DVI-D cable and a DVI to HDMI adapter for the consoles. I can connect the monitor to any console and it works fine, but it doesn't on the PC.However, the PC recognizes it via VGA, but not by DVI. I tried another monitor and the cable works fine. I.m very frustrated and don't know what else to do. Any help will greatly appreciated! Also, I did a clean install of my graphics driver and nothing. Also, I don't use the adapter to connect to the PC, just the DVI cable. Thanks in advance!
https://linustechtips.com/topic/614787-help-display-problem/
Did you feel any static when you disconnected the cable? You might've killed the DVI port. That happened to the HDMI connector on my Geforce 210 (the other two connectors, dvi and vga still work perfectly) tried a variety of cables and displays and the HDMI still wouldn't work. You unfortunately might have to settle with VGA for now :(
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/614787-help-display-problem/#findComment-7942071
You mean the port from the GPU? I'm currently using the DVI to VGA adapter that came with the graphics card to connect my second minitor and its working fine, but Dvi to Dvi with no adapter doesn't seem to work with my main monitor. :/
https://linustechtips.com/topic/614787-help-display-problem/#findComment-7942098
Ohhhh. Does the DVI port on said main monitor work when connected to another dvi output? The port might have died. If not then it's definitely a cable problem
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
https://linustechtips.com/topic/614787-help-display-problem/#findComment-7942117
Ok, the DVI port of the monitor works when I connect a console(Xbox One/Wii u), but when I connect it to pc it say no signal detected. I connect that cable to my second monitor and it works. Also I connected my pc to the livingroom TV via hdmi and it works too. Not sure whats wrong... Wheather I need a new monitor or a new GPU. :/
https://linustechtips.com/topic/614787-help-display-problem/#findComment-7942163
