My pc rig atm: Intel Core i7-5930K (15MB Cache, up to 3.70 GHz), s2011-3 2X Zotac GTX 1080 FE, 6 GB DDR5, 384-bit, 1228/7100 MHz ASUS X99-DELUXE/U3.1, s2011-3 DDR4 32GB (4x8GB) Corsair Vengeance HDD 3TB WD Black, 3.5", 7200RPM, 64MB Cache, SATA3, SSD 512GB Samsung 850 Pro CORSAIR Hydro Series H110i GT 280mm Extreme Performance Liquid CPU Cooler Corsair 760W, AX760, modular.
Problem: In games im getting fps but game lags. Should i upgrade my psu to better one (1200w corsair atx) or keep this one. I dont know how to fix stuttering or throttling. Im using old sli bridge for 1080p because im wating new one to come next week. With old GTX 980TI 6G OC my pc worked perfect! Is this happening cos of low wattage or smth else. Please help i dont know what to do?
https://linustechtips.com/topic/614627-psu-and-new-gpu-problem/
I doubt it's the PSU.
SLI might be the culprit here since it's quite well known to cause microstuttering.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/614627-psu-and-new-gpu-problem/#findComment-7940442
Your PSU is more than fine, don't bother with that.
https://linustechtips.com/topic/614627-psu-and-new-gpu-problem/#findComment-7940447
My guess is that the old bridge is the issue.
https://linustechtips.com/topic/614627-psu-and-new-gpu-problem/#findComment-7941041
the GTX1080 requires those hard SLi bridges for them to work properly in SLi
according to nVidia and reviewers, those SLi bridges that came with the mobo are not suitable
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/614627-psu-and-new-gpu-problem/#findComment-7941052
