Issue with GPU Upgrade
So I recently upgraded my gpu from the r9 270x dual x oc 4gb to the xfx dd r9 390. I USED to be able to record csgo in 1080p60 with minimal frame drops. Now i cant even record in 720p30 without being taken down to 50fps
CPU: A10-6800K
Mobo: Asus A78M-A
GPU: XFX Double Dissipation R9 390
https://linustechtips.com/topic/614585-issue-with-gpu-upgrade/
50fps in CSGO with a 390? How dude?
CPU: Intel Core i7 6950x @ 4.2GHz Custom Loop: EKWB Supremacy EVO MX, XSPC 360EX, EKWB 140 CE, Corsair 280mm, '70 Camaro rad, XSPC D5 Vario Pump, EK X3 250 res, Primochill Advanced LRT Crystal Clear (7/16" x 5/8"), XSPC Compression Fittings, Distilled Water and Primochill Utopia GPU: Gigabyte 1080ti Gaming OC RAM: 48gb SK Hynix 2400mhz MOBO: MSI X99S Gaming 7 PSU: Corsair RM1000 Case: Corsair 750D Storage: Samsung 960 EVO 256GB M.2, 4TB Toshiba X300, 2x 1TB Toshiba P300, 1TB WD Skorpion, 1TB Seagate Apple HDD, 750gb WD Black, 4x Micron C400 256gb Monitors: Acer Predator X34P; LG 29UM58; Dell 2405FPW Keyboards: 1987 IBM Model M; Razer Deathstalker Mouse: Razer Taipan (Black) Mousepad: Razer Goliathus Speed (Large) Headphones: Meze 99 Classics
https://linustechtips.com/topic/614585-issue-with-gpu-upgrade/#findComment-7940042
1 minute ago, jkeasley said:
Bad cpu
ohhhhhhhhhhhh.  got it
https://linustechtips.com/topic/614585-issue-with-gpu-upgrade/#findComment-7940052
8 minutes ago, Ronnie76 said:
Disable the APU somehow
you probably accidentally X-fire'd them
You can't crossfire an APU with a GPU of a different performance tier.  You can only combine APU's with R7 240's or R7 250/250X.  And it's not even supported by his APU.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/614585-issue-with-gpu-upgrade/#findComment-7940061
