2 minutes ago, ayyyyZJ said:
hey guys, just asking, what is the best fan to put on a radiator? i know static pressure fans are good, and i know noctua fans are amazing, so is there a noctua fan thats the best? im mainly asking what is the best fan for sound and performance on a radiator? Thanks!
NF-F12s work really well in radiators. If you have a considerable fan budget, also take a look at noiseblocker's NB-ELoops. Their build quality is second to none.
http://pcpartpicker.com/product/NN8Zxr/noiseblocker-case-fan-nbeloopb122
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/613684-best-radiator-fan/#findComment-7929766
Noctua are good i have radiator fans of deepcool captain 360 they are both well optimized for static and air flow
If you have radiator fans use them for now wait for the new corsair ML pro series which are well optimized for static pressure and airflow
these fans are more than enough and highly controlable as they can reach 2400 rpm
I can assure that they will satisfy you to your most and its worth wait
if you want fan now go with the one Energy core suggested
hope this will help you
https://linustechtips.com/topic/613684-best-radiator-fan/#findComment-7929787
What about those fans from EKWB? Vardar 1450rpm.
I will be buying 5 of those probbably. Right now I'm using some random case fans that I got spare, but it's time to get some Air Preassure fans.
So what do you guys think about EKWB fans at 1450rpm?
Looking for silent solution, that will be able to push air trough rad.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/613684-best-radiator-fan/#findComment-7932964
