This is my build in AUD. I'm planning to add a RX 480 so pretend the HD 5450 is a 480 which I've added a custom price of $300.
http://au.pcpartpicker.com/list/9smXLD
My questions are:
 - Could there be any improvments? (I'm looking to get the best possible price to performance PC)
 - It seems like the 7650K is really cheap for it's performance but is that including it's intergrated grpahics? (I compared it to my i5 4570 which costs sysnificantly more but it still won in overall performance)
Any replies would be greatly appreciated! :D
https://linustechtips.com/topic/613675-how-is-my-build/
you can get this instead
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($255.00 @ Centre Com)
Motherboard: Asus H110M-K Micro ATX LGA1151 Motherboard  ($85.00 @ Umart)
Memory: Kingston ValueRAM 8GB (1 x 8GB) DDR4-2133 Memory  ($39.00 @ PCCaseGear)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($65.00 @ IJK)
Case: BitFenix Comrade ATX Mid Tower Case  ($49.00 @ Mwave Australia)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply  ($79.00 @ PCCaseGear)
Optical Drive: LG GH24NSD1 DVD/CD Writer  ($19.00 @ PCCaseGear)
Other: Rx 480 ($300.00)
Total: $891.00
Generated by PCPartPicker 2016-06-20 12:44 AEST+1000
https://linustechtips.com/topic/613675-how-is-my-build/#findComment-7929702
Total: $891.00
What do you think about the 7650K? It's really cheap and gets a really good score on CPUBoss. I really like your build btw :D
https://linustechtips.com/topic/613675-how-is-my-build/#findComment-7929709
it's fine for budget builds, but i think its gonna bottleneck the rx 480.
https://linustechtips.com/topic/613675-how-is-my-build/#findComment-7929714
Do you use CPU Boss for comparing CPU's?
CPUBoss is a misleading piece of crap website, and it's completely inaccurate in terms of performance. Should never be used for comparing various CPUs.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/613675-how-is-my-build/#findComment-7929722
Really? I've always used it as a source of comparing CPUs and GPUs, what would you recommend instead?
https://linustechtips.com/topic/613675-how-is-my-build/#findComment-7929730
go check professional reviews of cpus instead of using cpuboss.
https://linustechtips.com/topic/613675-how-is-my-build/#findComment-7929758
14 minutes ago, MDH said:
Really? Because if you look at this http://cpuboss.com/cpus/Intel-Core-i5-4570-vs-AMD-A8-7650K comparison the A8 processor does better in performance for half the price.
It does not. Look at third-party benchmarks from professional reviewers.
___Boss is usually regarded universally as a inaccurate source of information.
https://linustechtips.com/topic/613675-how-is-my-build/#findComment-7929776
Which Benchmarking Tool in generally reliable for CPU's? Passmark?
Passmark isn't all that reliable for comparing CPUs. Valid, yes. But incomplete.
https://linustechtips.com/topic/613675-how-is-my-build/#findComment-7929811
Passmark is highly multithreaded optimized, which isn't realistic for desktop and gaming usage.
Generally I use multiple sources, but I definitely prefer Anandtech as they get into the more technical details if you enjoy that kind of stuff, but they're also very thorough with processors. Here's a review on the 7600 and 7850k.
http://www.anandtech.com/show/7677/amd-kaveri-review-a8-7600-a10-7850k/11
They show multiple use case scenarios but shockingly don't have gaming tests with a proper dedicated GPU.
Anyway, here's my recommendation of the build. You can likely survive without an optical drive, if not harvest one from another machine.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($275.00 @ Centre Com)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($42.90 @ Newegg Australia)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($68.00 @ CPL Online)
Video Card: Gigabyte Radeon HD 5450 1GB Video Card  ($300.00)
Case: Cooler Master N300 ATX Mid Tower Case  ($55.00 @ CPL Online)
Total: $904.90
Generated by PCPartPicker 2016-06-20 13:23 AEST+1000
if you have to insist you think for yourself, i'm not going to believe you.
https://linustechtips.com/topic/613675-how-is-my-build/#findComment-7929829
