i would try to go higher if possible it wil ldo normalish gaming at 1080p what parts u looking at ? the mobo usually is over expensive as ur buying features u wont need so u can cut costs there. power suppy houldnt be too expensive either as i doubt ull be needing anything past 600 w even if its gold rating :) whats ur budget ? my advice more money on cpu then gpu then psu then mobo :)
https://linustechtips.com/topic/613335-1151-help/#findComment-7925768
if you plan on quickly upgrading the cpu then fine, its still okay for games. but expect stuttering and some games not working with a dual core.
https://linustechtips.com/topic/613335-1151-help/#findComment-7925823
