So it's my first time building a PC. I have the parts selected which I have here:
http://pcpartpicker.com/list/4PG8d6
I plan to add an rx 470 GPU once it comes out. Being that this is my first build, can you guys give me some suggestions on how I could save money on this build without too much effect on the performance, or if this PC will even perform well at all. Also, PC Part Picker said, " Some Intel B85 chipset motherboards may need a BIOS update prior to using Haswell Refresh CPUs ". Is this something I should worry about? I'm looking to build a PC that can run games like GTA V and DayZ. Sorry, I am new to this.
https://linustechtips.com/topic/613309-first-build/
what's your budget? what resolution are you gaming on? do you need a OS? do you need a monitor? do you need a keyboard and mouse?
and the BIOS update just means if you get a older board (usally only older ones) youll need a CPU that works on the BIOS to update it so your CPU you are buying needs, but usally you dont have to worry about that.
https://linustechtips.com/topic/613309-first-build/#findComment-7925437
get this instead.
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($45.99 @ Amazon)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2400 Memory  ($29.99 @ SuperBiiz)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($34.99 @ Newegg)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($41.99 @ NCIX US)
Case: BitFenix Comrade ATX Mid Tower Case  ($22.99 @ NCIX US)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ Micro Center)
Total: $400.93
Generated by PCPartPicker 2016-06-19 02:15 EDT-0400
https://linustechtips.com/topic/613309-first-build/#findComment-7925466
Your part choices are pretty good, but I'd like to know a few things.
What's your budget?
What resolution are you aiming to work/game at?
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
https://linustechtips.com/topic/613309-first-build/#findComment-7925474
My budget is from $500-$700. I'm gaming on a 1080p monitor. I'm going to get a Windows 10 Product Key for $20 and I already have a keyboard and mouse.
https://linustechtips.com/topic/613309-first-build/#findComment-7926012
What's your budget?
My budget is around $500-$700. I want to get the most I can get for that price range. I am going to game on a 1080p monitor and hope to be able to run most games at 50+ FPS.
https://linustechtips.com/topic/613309-first-build/#findComment-7926017
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.99 @ NCIX US)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard  ($54.99 @ Newegg)
Memory: GeIL EVO POTENZA 16GB (2 x 8GB) DDR4-2400 Memory  ($48.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($87.59 @ OutletPC)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Newegg)
Other: Rx 480 ($199.99)
Total: $709.41
Generated by PCPartPicker 2016-06-19 07:05 EDT-0400
https://linustechtips.com/topic/613309-first-build/#findComment-7926194
Total: $709.41
this, but we dont know about the 480 yet, so look up benchmarks and all that before you buy it
https://linustechtips.com/topic/613309-first-build/#findComment-7927291
Total: $709.41
Is the SSD necessary?
https://linustechtips.com/topic/613309-first-build/#findComment-7927635
Got it.
And if you can wait till June 29th for the GPU, switch the R9 390 for an RX 480.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($197.99 @ SuperBiiz)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2133 Memory  ($31.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($318.99 @ SuperBiiz)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  ($29.99 @ NCIX US)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply  ($62.99 @ SuperBiiz)
Total: $735.43
Generated by PCPartPicker 2016-06-19 13:49 EDT-0400
Quote
https://linustechtips.com/topic/613309-first-build/#findComment-7927821
nope, but its very good to have as a boot drive if you can afford it.
https://linustechtips.com/topic/613309-first-build/#findComment-7929057
