Audio coming from motherboard?
Ryank720
I had my earbuds plugged into my front panel, but I noticed that my windows notification sounds and steam chat sounds were not coming from the earbuds.  I unplugged them, and with no audio devices plugged in, i still heard the sounds.  Not only that but I have sound notifications disabled in Steam but heard the noises anyway.  Any idea where this is coming from? I'm assuming it's the motherboard but why is it doing this, and why only these sounds and nothing else (doesn't play youtube audio, clicking the audio setting in the task bar, etc)?
Edit: It's a brand new desktop that I just built.  I have not installed any drivers yet other than the video.  Here are the specs:
ASUS mITX Z170I Pro Gaming motherboard
Gigabyte GTX 1070
GeIL EVO Potenza 16Gb
Samsung 850 Evo 500Gb
Windows 10 Pro
Fractal Design Node 202 with built in 450 SFX Power supply
It sounds like the sound may be coming from a speaker from elsewhere on your computer.
It is unheard of for modern desktop computers to broadcast sound directly from the motherboard.
I must then draw the logical conclusion that you may still have something plugged into your computer.
You know that "speaker" thing that comes with your motherboard? It's coming from that when you plug it in, even though that's for initial boot or something.
I don't have any speakers plugged into the desktop though.  Just my monitor, mouse, and keyboard; none of which have a speaker.
Sorry but I'm not sure which speaker thing you're talking about. Could you clarify?
download.jpg this thing
Ah I see.  I didn't install that, unless it came preinstalled
The monitor may have audio with it.
Check to see if that is the case.
To redirect audio to your earbuds, simply right click on the audio on your bottom right hand side corner of your screen, and select playback devices.
From there, you can select your earbuds
-tips fedora
-tips fedora
All the normal input was working through the earbuds, it's just that those 2 other sounds were coming from somewhere else.  I'm pretty sure this monitor doesn't have speakers either.  Quite the mystery lol
-tips fedora
only if he has true/tru audio or Nvidia's HDMI audio support
or even if he is plugged in through HDMI or DisplayPort
I'm using DVI plugged into a 10 year old monitor.
some computers have small speakers to beep when the cmos battery is depleted.
Perhaps that's the case with your computer.
To verify, check your motherboard supplier for more information on audio compliance.
I'm a little tired so I'll check that tomorrow. Although I'm pretty sure it's not that. I asked my friend to test it and the only time I heard the sound was when he sent me a message. And the sound was identical to the steam notification sound
