Issue With >8GB Memory
Solved by UL_42L,
Problem solved! The limit for my memory speed is 533/1066 MHz and the system did not automatically underclock it! Once I lowered the clock rate, it worked perfectly! Thank you very much for your help, @cayphed!
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
3
6
Ishikudeska ·
Posted in New Builds and Planning2
play_circle_filled
Latest From ShortCircuit:
