i picked up a nzxt HUE+ off of amazon as long as you got a internal MB usb 2.0 header is nice . if you dont just need a micro cable . cablemods RGB kit is good also  if you can find it in stock anywhere
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
https://linustechtips.com/topic/613179-which-rgb-led-kit/#findComment-7923893
well.. here in germany the hue+ starts at around 65€.. thats a lot of money for "only" LED's.. a 20M RGB Cable would cost around 19€..
https://linustechtips.com/topic/613179-which-rgb-led-kit/#findComment-7923911
that ant much more then i paid they ant cheap but  from using it its worth every pennie . if you dont mind having to use the IR controller then go with cablemod/ other generic ones. but for the hue+ i can tell they put alot of money and effort to make it dam perfect , some minor bugs on thing but its wonderful
main rig
https://linustechtips.com/topic/613179-which-rgb-led-kit/#findComment-7924251
3 hours ago, Evann said:
Hi,
so i want to lighten up my Phanteks Enthoo Evolv ATX a bit.. and i thought about buying RGB LED Strips for it.. do you have any recommendations? (:
Thank you! :)
(sorry if this is the wrong section, i wasn't sure where to put)
how about you get one of out 30CM or 60CM RGB Kits? They are available here and ship from Germany: https://eustore.cablemod.com/
https://linustechtips.com/topic/613179-which-rgb-led-kit/#findComment-7924563
