I recently went on pcpartpicker and i started to go to the build ive been looking for and wanting , and im wondering if this build is good enough to be able to stream and play arma 3 and csgo at the same time ?
Here is the link to it.
http://pcpartpicker.com/list/jqzwPs
I'm open to suggestions that can make it cheaper/better aswell. :)
https://linustechtips.com/topic/613167-help-please-with-build/
You look pretty good! Here are the things I would suggest
-More RAM (8 gb is a little low to stream and play on high or ultra at the same time)
-Why not just get a GTX 1070? For $200 more dollars you could have a GPU miles better than the GTX 960
-If you want to lower the price you could get this mouse http://www.newegg.com/Product/Product.aspx?Item=9SIA9KW43S2259&cm_re=steel_series-_-26-249-176-_-Product, ive been using it for the past year its awesome in my opinion, rather than that overpriced Razer garbage
-you could also go with a 500BG HDD if you wanted and thought it would give you enough space
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923736
1 minute ago, wangyuji431 said:
How exactly do you plan on playing them both at the same time?
You could rebind keys and then split the screen, I guess :/
The build seems very solid, and I'm quite sure it could theoretically do both, but I;m not quite sure why you'd want to.
 Sorry let me rephrase, I meant be able to stream arma 3. and also be able to stream arma 3. not at the same time, just in general
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923740
Yes, this build will allow you to both play and stream arma 3, maybe even at the same time lol.
It could also do CS:GO concurrently or on the side.
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923745
3 minutes ago, pabG said:
I don't want my budget to exceed 1,500$
If you dont want your budget to exceed $1500 than do exactly what Jeezy said, get a cheaper mouse, keyboard, or headset.  A 1070 or 1080 is a must,  youd be dumb to get a 900 series at this point, especially a 960
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923747
Waiting a week and a bit for the RX 480 is also an option.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923751
5 minutes ago, GreezyJeezy said:
and why are you getting a K processor and H series board?
Could you explain this? I'm still semi new to pc  building and what do you recommend i get ? for the keyboard and headset? for the headset thats good and has long durability and 7.1 surround.
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923760
I also saw that you have a 6700K processor and an H series board, which wont allow you to overclock your K series processor,  if you dont plan on over clocking just get the 6700, will save you some money there
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923762
So keeping the H board will save me some money? and i wont need to overclock right? to be able to stream fine and play arma 3 and etc
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923770
Keeping the H board will save you money,  BUT pairing it with a K series processor dosnt make sense
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923781
So which one do you recommend i get? that can fit the processor and not have me exceed 1,500$
Well if you wanna save money, keep the H series board, and just get the normal i7 6700, save about $20 bucks there.
Also this keyboard has MX Cherry Reds, is cheaper, and in my opinion is better,  I have had a Corsair keyboard for a while now and will never get anything else.
- Keyboard http://www.newegg.com/Product/Product.aspx?Item=N82E16823816015&cm_re=Corsair_keyboard-_-23-816-015-_-Product
-Processor http://www.newegg.com/Product/Product.aspx?Item=N82E16819117560&cm_re=6700-_-19-117-560-_-Product
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923797
What do you think of this keyboard?
https://www.amazon.com/CM-Storm-QuickFire-TK-Mechanical/dp/B00AOIRCI6?ie=UTF8&tag=pcpapi-20
also in order to make sure i dont exceed the budget what would i have to remove or get cheaper to get the 1070 ?
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923816
All i can say about that keyboard is you get what you pay for,  id never use a CM keyboard but if your crunching numbers that hard already I guess go for it.
And like I said earlier, maybe a 500GB HDD instead of your 1TB?  A cheaper mousepad? or even a cheaper desk?  All I can say is, a 1070 is something that should have entered your build first and you build around that
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923826
13 minutes ago, pabG said:
The ones im seeing here on pcpart picker are basically the same price as the 1tb one i have here, and the mousepad i have because of csgo,
I felt like being nice and put something together for you,  it dosnt have a headset or desk included but its way better bang for your buck.
http://pcpartpicker.com/list/9PdRBP
https://linustechtips.com/topic/613167-help-please-with-build/#findComment-7923955
