Hey I have a E8400 with GA-G33M-DS2R motherboard 4 GB ddr2 ram and 430 watt psu and I'm looking at swapping my Galaxy GTX 260 and putting a MSI R7 370 Gaming 4GB would that be good idea or should I first invest into a new cpu and everything before putting the msi R7 in as I play ARK survival evolved and bear lyrics able to play. Please help
Thanks
https://linustechtips.com/topic/612874-help-i-have-e8400/
Thanks
Download MSI afterburner, setup on screen statistics to show you your CPU and GPU utilization, and make the call from there. Investing in a better GPU will definitely help, but whether or not it helps with ARK will depend on what's currently bottle necking you.
Based on what I can find though, your CPU should be sufficient to run ARK, so upgrading your GPU would definitely provide a large benefit.
https://linustechtips.com/topic/612874-help-i-have-e8400/#findComment-7920862
Cool thankyou I did and my cpu is at 80% when doing test but I think my GPU is crashing as I can not do the stres test on it
https://linustechtips.com/topic/612874-help-i-have-e8400/#findComment-7920891
i'd recommend seeing if there are any core 2 quads/quad core xeons used for cheap, an e8400 isn't enough for gaming. intensely low ipc and no extra cores to make up for it. for the gpu, maybe wait for the Rx 460, it should be at around the sane price and performs similar to the gtx 960/r9 380 while eating much less power.
https://linustechtips.com/topic/612874-help-i-have-e8400/#findComment-7920899
let us all remember now and today, computers do not like abuse, they will fight back!
Old Skool KILLBOX. XEON E5640 4.0ghz / ASUS P6X58D-E ~ Noctua NH-L12 ~ eVGA GTX 670 SC 2GB 1312/7000 ~ 4TB 7200 RPM RAID0 ~ CoolerMaster Haf 922 ~ DELL P214H 23" 1080 IPS 2ms ~ HP w2007v 1680x1050. Now Playing: Splinter Cell OG XBOX / CSGO PC
Original XBOX - Xecuter 2 4981.67 Bios. Playstation 2 Slim SCPH-70002. Sega Dreamcast. N64
https://linustechtips.com/topic/612874-help-i-have-e8400/#findComment-7920904
https://linustechtips.com/topic/612874-help-i-have-e8400/#findComment-7920911
