https://linustechtips.com/topic/612817-led-cable-converter-help/#findComment-7920261
1 hour ago, ToeJullar said:
Looking for a converter to go from black 4 pin fan/pwm styler LED cable connector to a 4 pin style as seen on the white one.
Anyone know where I can find one?  Can solder/splice if needed
As mentioned you will most likely need to make an adapter to work with the SMD5050 type of LED's however I do think Addoncustoms does have an adapter like that of sorts for the Phanteks last time I checked. @AddonCustoms
https://linustechtips.com/topic/612817-led-cable-converter-help/#findComment-7920449
I found a video on YouTube actually where someone did this mod and it looks like he used this cable and then soldered it onto one of the controllers extensions pieces.
https://www.amazon.com/gp/aw/d/B0140KO7K4/ref=mp_s_a_1_fkmr0_1?qid=1466224693&sr=8-1-fkmr0&pi=AC_SX236_SY340_FMwebp_QL65
I might use those cables @TheKDub linked though.  Might make for less of a mess for what I'm planning.
https://linustechtips.com/topic/612817-led-cable-converter-help/#findComment-7920577
