Newly built computer will not boot up
Go to solution Solved by SHUG,
I just found a VGA cable and plugged it in. all good now except that i feel like a tard :)
I'm not sure if this is the right section to post this but I am having a lot of trouble booting up my new computer. essentially what happens is I turn it on, the LEDs and fans spin, the hard drive boots up, then after about 15 seconds it will turn off and restart again. I don't think it is a short because i have reseated the mobo among other components and i can keep the everything inside the PC running if I press the case's refresh button every few seconds. I have only tried booting it with a HDMI cable because i can't find a VGA so could this be the problem? any help would be greatly appreciated.
Thanks, Hugo
P.S. I have tried a few troubleshooting guides but nothing seems to have worked.
https://linustechtips.com/topic/612747-newly-built-computer-will-not-boot-up/
