Hey folks.  I was looking for a replacement cable for my Sennheiser HD 600 headphones.  Not super concerned about the price of the cable.  Dropping $50 on a cable for a pair of almost $400 headphones, I can rationalize that.  However, I am looking for a shorter cable.  Nothing is wrong with the cable they shipped with, it's just too long for what I generally would use them for.  Primarily gaming and listening to music at my desk.  But on the off chance I want to move around my house and use the headphones, a shorter cable would be nice.  So what would you guys use for a replacement if they were your headphones?
You have been Spfinated!
https://linustechtips.com/topic/612682-hd-600-replacement-cable-suggestions/
https://www.amazon.com/Replacement-Cable-SENNHEISER-Headphones-HD650/dp/B0028PGXRE
http://www.headphone.com/products/sennheiser-hd650-replacement-stock-cable
or
http://www.ebay.com/itm/Black-Replacement-Cable-For-Sennheiser-HD414-HD430-HD650-HD600-HD580-headphone-/281645092022
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
If you can ever do it, bestintheverse makes mean cables.
They're expensive, and they close up shop frequently so they dont get too bogged down, but man they look cool.
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
Thanks!  I'll look into it.
