Cpu overheating
Go to solution Solved by manikyath,
is the pump still purring?
Just yesterday I was replacing the fan at the back of my computer and the two for the hard drives. My CPU is water cooled with a 280mm rad. Without changing any of the cables or fans for my cpu cooler now my cpu hits 100c and will turn it self off. Why is doing this?
Case: http://m.newegg.com/Product/index?itemnumber=N82E16811119260
Fans:   http://www.corsair.com/en-us/air-series-af120-performance-edition-high-airflow-120mm-fan-twin-pack  (performance edition not quiet)
https://linustechtips.com/topic/612678-cpu-overheating/
is the pump working?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/612678-cpu-overheating/#findComment-7918751
