I have problem when trying to connect to V's online,when i try to connect it says something along these lines:
"You were unable to connect to online since your game doesnt have latest patch installed,please try restarting your game with internet connection"
I have everything updated,at least my launcher doesnt update,i doent see solution on forums or neither else,anybody had this prob before?
https://linustechtips.com/topic/612353-gta-v-online-problem/
I had this issue for a long time I ended up reinstalling the game and it worked after that.
https://linustechtips.com/topic/612353-gta-v-online-problem/#findComment-7914902
pc or console?
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/612353-gta-v-online-problem/#findComment-7914915
try restarting steam/pc and check the games cache
https://linustechtips.com/topic/612353-gta-v-online-problem/#findComment-7914930
1 minute ago, ELSknutson said:
a guide? just uninstall the game and re download it
Well,since its 60gigs i need a lot of time to download and it keeps losing connection to theyre servers after 3/4 hrs of download and then 3/4 hrs of computer on time goes in nothing,i thought there is some way to "reverify" game files or something..
https://linustechtips.com/topic/612353-gta-v-online-problem/#findComment-7914936
do it overnight, or when your sleeping, (some people sleep in the day)
and yes you can just verify the game integ but that doesn't always work when reinstalling usally does if its a problem with how it installed
https://linustechtips.com/topic/612353-gta-v-online-problem/#findComment-7914944
I do it overnight i have 500kbps down,after 3/4hrs of download laucher loses connection to theyre servers and am screwed...am really confused that there is no way somone else fixed the same issue..
https://linustechtips.com/topic/612353-gta-v-online-problem/#findComment-7914947
well if there is connection loss every single time you download it its your ISP's fault,
you can verify the game intreg like i said but it might not work
https://linustechtips.com/topic/612353-gta-v-online-problem/#findComment-7914954
Ill try Today with verifying files,i havent knew about that,thanks for letting me know
https://linustechtips.com/topic/612353-gta-v-online-problem/#findComment-7916089
  • 2 weeks later...
For the record i solved the problem.
No need to reinstall or anything just run it in safe mode and itll download all avaibable updates then this shoud work.
I discovered this acidently when my game blocked i ended it in task manager when i tried to boot up again it showed my "GTA stopped working properly bla bla bla" and i acidently pressed safe instead normaln mode and it started updating lol :D
https://linustechtips.com/topic/612353-gta-v-online-problem/#findComment-7964031
