show Northbridge Speed
Solved by glitchmaster0001,
6 minutes ago, Poohl said:What software could I use, to find out about my northbridge frequency? In the bios i could set a multiplier, but its set to auto and i can't find out that "auto" value. I overclocked my FSB and it seems like only the Northbridge is causing problems.
CPUz show nb frequency all you have to do is set the strap northbridge to fsb thing to 400mhz then your ram to the lowest multiplier, then your ram and northbridge will be running at the identical speed. then to make things more stable if the ram is running beyond its rated speed you loosen the ram's timmings a notch or two then give it a voltage bump by .05 or .1 depending on how high your overclocking
