So I have a edimax ew-7288APC Range extender, I want to make my downstairs of my house have stronger wifi. There is no way I can wire a Ethernet cable from upstairs to downstairs. Is there a way that I can extend my wifi connection without the Ethernet cable connected?
https://linustechtips.com/topic/612036-need-help-with-range-extender/
1 hour ago, frostyck said:
I am pretty sure it has a wifi bridge mode, as most of the extenders do. There should be a switch or a toggle on the base for a bridge, turn that on, then connect to the device with a phone or a laptop.
What is wifi bridge?
There is no way I can run the ethernet cabe from my router to my extender downstairs.
4 minutes ago, frostyck said:
Normally, i never post links, but this is the easiest way to clear up any confusion.
http://www.edimax.com/edimax/mw/cufiles/files/download/manual/EW-7288APC_User_Manual_English.pdf
Check it out.
So in wifi bridge mode no ethernet cable will needed to be connected to the router in order for the range extender to work right?
20 minutes ago, AlanAlan said:
no i mean like there will not be a Ethernet cable running from the router to this right?
You are correct but you can plug an ethernet cable from the bridge to your pc or whatever ethernet enable device you have
Main PC:
OS: Windows 10 Pro, Motherboard: Asus ROG Strix X570-E Gaming, CPU: Ryzen 9 3900X, Cooler: NZXT Kraken X63RAMCorsair Vengeance RGB Pro 32 GB DDR4-3200 CL16, GPU: Asus GeForce RTX 2080 SUPER STRIX GAMING, Case: NZXT H710, StorageSamsung 970 Evo Plus 1 TB NVME, Sabrent Rocket 2 TB NVME, and WD Blue 4TB 2.5"PSU: NZXT C 850 W 80+ Gold
Home Network:
Router: Ubiquiti USG-3, APs: Ubiquiti UAP-AC-LR and Ubiquiti USP-AC-PRO, Switches: Ubiquiti US-16-150W
