Hello guys. I want a buckling spring keyboard with thin bezels like the Ducky Shine 5 and Pok3r. I also see that the keys are always slanted so is it also possible to get it straight up or in a similar position to the Pok3r?
I own a Pok3r (its dirty as hell) and I like the layout and look of it. I thought it might be possible just to get a custom made one. Is it also possible to get it in TKL or 60%?
https://linustechtips.com/topic/611513-buckling-spring-keyboards/
http://clickykeyboards.com/ sells original Model M's, the stock ranges quite alot, you might have to look every once and a while if they have a Space Saver in stock.
http://www.pckeyboard.com/ sells new Model M's, they make to order but off a base model, I don't think they sell a 10 keyless model.
There isn't much range other than that for buckling switches, there were some buckling switch clones in the 90's, that is about it though.
2 minutes ago, Heavy Duty in the Booty said:
So is it possible to get thinner bezels but with full keyboard layout. Can i also drop the F1-12 Layout at the top as well or does the company have to keep it?
I don't really know, I left out the base model M / Classic since they are very not what you want, maybe look at these and compromise on one.
M15 Options by IBM
http://clickykeyboards.com/product/1995-lexmark-model-m15-ergonomic-1428401-external-num-pad-22-nov-1995/
M2
http://clickykeyboards.com/product/ibm-model-m2-1395300-made-by-ibm-06-30-1993/
Space Saver
http://clickykeyboards.com/product/1988-ibm-model-m-84-key-space-saving-1392934-21-jan-88/
Space Saver M
http://www.pckeyboard.com/page/product/UNIZPHA
Ultra Classic
http://www.pckeyboard.com/page/product/UNI0P4A
EnduraPro
http://www.pckeyboard.com/page/product/UNI0PGA
