Need a CPU cooler for air 240
Solved by LogicalDrm,
1 hour ago, TheMidnightNarwhal said:Yeah I'l have to cancel the Be Quiet idea they're out of stock everywhere apparently.
So any suggestions?
With that budget anything from Noctua is out. From all coolers PCPP lists, I would pick Phanteks https://ca.pcpartpicker.com/product/8t648d/phanteks-cpu-cooler-phtc12lsbk . Another option is small tower like TX3 from CM. It will be louder than Phanteks because of 92mm fan, but performs bit better. Difference is few degrees on OC'd system... Looks on both are, well, not the greatest. And you can always change more suitable fan to Phanteks.
