So this is my first PC build, am I getting good a good value? Am I missing anything? Any other comments? I was going for an around $900 gaming pc that could also handle some cad and rendering (Excluding peripherals). I want to be able to expand later, second GPU, water cooling for OC, more RAM, but not yet. Thanks! http://pcpartpicker.com/list/M2y99W
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/611256-first-pc-build/
3 minutes ago, sazrocks said:
So this is my first PC build, am I getting good a good value? Am I missing anything? Any other comments? I was going for an around $900 gaming pc (Excluding peripherals). I want to be able to expand later, second GPU, water cooling for OC, more RAM, but not yet. Thanks!
I think you forgot something. :)
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903550
Whoops! Added the link the OP.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903564
PCPartPicker part list: http://pcpartpicker.com/list/pCxNGf
Price breakdown by merchant: http://pcpartpicker.com/list/pCxNGf/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard  ($49.99 @ Newegg)
Memory: Team Dark 16GB (2 x 8GB) DDR3-1600 Memory  ($49.99 @ Newegg)
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive  ($54.00 @ Amazon)
Video Card: PowerColor Radeon R9 380X 4GB PCS+ Myst. Edition Video Card  ($189.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($59.99 @ Micro Center)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ NCIX US)
Total: $698.94
Generated by PCPartPicker 2016-06-14 16:45 EDT-0400
Worth waiting for the 480.
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903577
And maybe how he should wait for the rx480 and get something other than the CX PSUs? (A PSU from seasonic or XFX (except the XT series) are all better than the green label CX ones and with their cheapest ones, about the same or slightly worse quality than the grey labeled CX PSUs but not worth to take the risk IMO)
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903581
Grey units are S12ll from Seasonic level. They're fine.
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903583
Yah, I did say that :) (the one you listed is grey labeled so it's all guld).
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903590
If you want to OC:
PCPartPicker part list: http://pcpartpicker.com/list/JRcFTH
Price breakdown by merchant: http://pcpartpicker.com/list/JRcFTH/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($318.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.49 @ Amazon)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($87.99 @ SuperBiiz)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($35.49 @ NCIX US)
Total: $880.92
Generated by PCPartPicker 2016-06-14 16:49 EDT-0400
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903595
There ya go!
Now, I would change a few things. First the motherboard. I would go with a Z97 board, I would also suggest a different brand (Asus, Gigabyte, MSI). You'll also want to make sure you get an SSD, it'll make a big difference. Next I wouldn't get the 960 at this point. AMD has the RX 480 coming out soon and it looks to be a great value card priced around $200. It's also worth getting a better PSU. You want to make sure you have something that will last and give you the OC headroom you need in the long run.
Here is an updated build list with my recommendations. Please note there is no GPU as the 480 is not out yet. This might be slightly over your budget but I think these changes would be worth it.
http://pcpartpicker.com/list/88GwPs
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903606
Miss interpreted your not worth the risk statement then, my bad.
As in not all CX PSUs that are being sold are grey labeled so some are still the good ol' shitty ass components that plagued the old CX line up :) but it's all guld :D
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903609
2 minutes ago, Kryptyx said:
There ya go!
Different PSU, NEX series is sub-par and not worth their cost. For CAD and rendering, more cores and more ram will benefit him.
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903618
Fair enough, I'm not an expert on PSUs :(
I was gonna suggest an i7 but wasn't sure about budget concerns.
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903632
6 minutes ago, Kryptyx said:
There ya go!
Different PSU...it's overpriced. Also, there's no point spending $900 on a system with no dGPU and has an i5 (if you're going for the future then you didn't even recommend skylake...pfffttt I'm sorry but that's kinda pathetic).
Agreed :)
Which in that case, the Xeon 1231v3 fits that criteria perfectly :)
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903640
Agreed :)
11 minutes ago, Starelementpoke said:
If you want to OC:
Total: $880.92
4790k easily achievable.
https://linustechtips.com/topic/611256-first-pc-build/#findComment-7903645
